I've noticed this a few times recently since it's been cold. I lift up on the shifter lever to put the car in reverse & it wont go over all the way. The lever gets stuck at the top of the shifter, & I have to manually push it back down. Usuallly I can get it into reverse after fiddling with it a few times by rolling forward in 1st & double clutching into reverse. However this morning I couldn't get it to go in at all when leaving my home. I pushed the car out into the drive way & then took off to work. Made it to work 30 minutes later, pulled into parking garage & everything was fine...slipped right into reverse w/o any issue & the lever retracted on its own just fine.
Anyone else have this issue and/or know of a fix? It's just a minor inconvenience, but annoying nonetheless. I typically try to park in places where I can pull forward to get out, but that's not always possible.
