Alright alright alright, here we go again. Carbon Fiber license plate frame? Is it tacky? I dunno, maybe! Is this stupid? Yes. Does my girlfriend think I’m insane? Also, yes. The previous owner had a license plate frame with a little Union Jack logo at the bottom and I’ve just sort of kept it. But as with my mission of removing as much black plastic/metal on the exterior as I can I decided to reproduce it. This was also a good item to practice using some new materials and techniques since it’s a fairly simple part.
Here's the original part, I’ve already removed the Union Jack emblem.
Next was to block in the overhangs and cover the live edge/fill in the holes with plasticine clay.
This is one of the new products I wanted to try, it’s Smooth-On’s EpoxAcoat product. I like that it is brush-on and not pour on. That saves a lot of time in the fact that you don’t have to build up barriers for the pour. Their release agent was also nice that you can brush it on as well, no spraying PVA, and it released pretty well. Surface detail was nicely retained.
Link to their product: EpoxAcoat™, Surface Coat Epoxies
Only downside is that it’s a fairly brittle plastic when it hardens. I didn’t do enough coats on the first try. Here it is (flipped over).
Time for the other side. Again, covered live edges with plasticine clay.
Gelcoat applied. Added more layers this time.
Resulting halves.
Forgot to take a picture, but I then applied alternating layers of the West Marine 105 Epoxy/207 Hardener system and sheets of carbon fiber. I did 4 layers of CF, and started and ended with coats of epoxy. Then I clamped it all together and let sit till the next day.
Out of the mold, which I broke! I also squished too hard with the clamps and distorted the weave. You can really see the pattern blow up in the top center and the left side.
Trimmed close with a Dremel, then hand sanded to the edges.
My solution was to the weave distortion was to add a fresh layer over the front. I tried to make sure to have some plasticine clay over where the indent was to keep the form, but that didn’t work too well. It’s still recessed, but not as crisply. I had thought of a way to fix it, but I also thought that it wasn’t all that bad and just moved forward.
Resulting halves.
