1 - 7 of 7 Posts
i took out all the carpet out of the trunk and only took out the carpet on the door sill on the interior. does anyone know the best way to get that sticky stuff off under the velcro that the carpet was attached to? i want to know how to get it off before i pull off all the velcro.
Goof Off available almost everywhere, even in grocery stores.
Jerry
Home Depot, Lowes. Buy plenty. A little does not go a long way. Spray and let soak several times. If you care about the lok of your aluminum, don't scrub it with anything remotely abrasive. Your finders should be enough. Moistenblockens? also make an adhesive remover which has also brought me luck.
Hope this helps.
I'd stay away from goof off, it it very potent and ruins some serfaces, Goo Gone on the other hand (the citrus stuff) works great on anything and Home Depot sells it.
I use Goof Off all the time. Don't worry about it on the aluminum. It's those rivets I'd be more concerned about after the carpet removal.
1 - 7 of 7 Posts
