Just did a a laser alignment and my caster is about 1 degree different....how is this fixed?
I thought these removable shims adjusted camber, not caster?My Elise came from the factory with the shim/washer fore on one side and aft on the other side. My mechanic noticed the caster being off and figured it out. Now its balanced. I guess this kind of things happen w/ hand built cars. I also found a socket stuck to my speaker magnate... a little gift from Lotus.![]()
There are removable shims near the upper ball joint that set camber (at 7 in this picture). The ones for caster are at each of the upper arm mounting bolts, fore and aft (24 and 29). Shim(s) are removed from one end (say, the front) and placed at the other end to move the upper ball joint fore and aft.I thought these removable shims adjusted camber, not caster?
Moving the big shims is relatively easy, but there are some tiny washer spacers that are a complete pain in the *ss to get back in there and lined up with the bolts.Ahhh, I wasn't aware of those shims. Thanks! The diagaram helps a bunch.How hard is it to get to these shims by hand? I've been contemplating increasing caster, I've been seeking a firmer/more weighted steering feel..
How tough is it to remove bolt #29 (red arrow below)? It looks like the rack boot/steering tie rod would interfere with backing it out enough to move the washers around...Moving the big shims is relatively easy, but there are some tiny washer spacers that are a complete pain in the *ss to get back in there and lined up with the bolts.
I popped the outer tie rod and swung the steering link back and out of the way. Once I did that it was easy to get the bolt out. I forget, but I may have turned the steering a bit too.How tough is it to remove bolt #29 (red arrow below)? It looks like the rack boot/steering tie rod would interfere with backing it out enough to move the washers around...
Yup, I kind of figured you'd have to do that... thanks!I popped the outer tie rod and swung the steering link back and out of the way. Once I did that it was easy to get the bolt out. I forget, but I may have turned the steering a bit too.
I did the caster adjustment tonight... maxed out the caster by moving all but one washer in front of each of the bushings. I actually used a little rubber cement to hold the smaller washers together while refitting them... and a complete set of drift pins to help line everything up. Not as bad as I thought, but still no picnic.Moving the big shims is relatively easy, but there are some tiny washer spacers that are a complete pain in the *ss to get back in there and lined up with the bolts.
Well, it's interesting that the two sides were not set symmetrically from the factory... the left side was 0/4 (0 washers ahead of bushing/4 washers behind) and the right side was 1/3. I measured the starting caster as 3.4º left and 3.2º right. After setting the caster both sides' washers are 3/1, and the caster I measured was 4.6º left and 4.0º right. The manual says 0.4º of caster change per washer... which seems to be accurate.Out of curiosity, how much caster did you get?
If I have to do it again I'll try the rubber cement trick. I forgot to mention I made a pointed bolt to center the washers once they were nearly in place.
Driven it yet? You may get some pulling with that much more caster on the driver's side.Well, it's interesting that the two sides were not set symmetrically from the factory... the left side was 0/4 (0 washers ahead of bushing/4 washers behind) and the right side was 1/3. I measured the starting caster as 3.4º left and 3.2º right. After setting the caster both sides' washers are 3/1, and the caster I measured was 4.6º left and 4.0º right. The manual says 0.4º of caster change per washer... which seems to be accurate.
Yes... I was wondering whether I'd notice the asymmetry; it feels fine so far. Haven't taken it on the freeway yet though. I'm going to do another measurement of caster after put a few more miles on the car. The factory spec is 0.35º difference side/side...Driven it yet? You may get some pulling with that much more caster on the driver's side.
If it drives OK, if it were me I'd leave it alone. A little more caster won't hurt anything.Yes... I was wondering whether I'd notice the asymmetry; it feels fine so far. Haven't taken it on the freeway yet though. I'm going to do another measurement of caster after put a few more miles on the car. The factory spec is 0.35º difference side/side...
Agreed :up:If it drives OK, if it were me I'd leave it alone. A little more caster won't hurt anything.
After a much longer test drive, it does seem like 0.6º of difference is too much... there seemed to be a perceptible pull to the weaker side. I moved around one set of washers on the left side and now I'm back to a 0.2º difference, and the steering feels much more neutral. Of course, with more caster, the car is more sensitive to crowning and irregular surfaces anyway...Driven it yet? You may get some pulling with that much more caster on the driver's side.
You're right, and I will... I wanted to finalize the caster setting first.You probably already did this but don't forget to reset the toe. Changing the castor changes the toe.
