1 - 6 of 6 Posts
Hi all. Just bought an 06 Elise and the locks were not working. I replaces fuse 22 the 7.5A and all worked for about 5 minutes. The fuse blew again and blows every time I press the fob. Could this be a bad CDL or should I check something else?
I haven't examined the wiring diagram, but first guess is a bad lock actuator
you could disconnect one then the other and see what happens
Yep...it was the drives side actuator. When unplugged the passenger side works fine and no blown fuse. Plugged it back in and fuse blows. I am going to order a new one from lotus garage unless there is a better place to source one. Thanks for the help!
Yes I see that now...bummer. Lotus parts online seems to be thriving, will go there. Thanks again!
1 - 6 of 6 Posts
