1 - 3 of 3 Posts
I'm going to be picking up my first Elise this week that has black CE28's wearing Toyo Proxes RA1's in sizes 225/45/15 and 245/45/16. I am told they are about 50% worn. Are these pure track tires? Am I going to be ok driving these around on the street until they wear out? What about in the (florida) rain? I did a check on Tirerack and discount tire and there aren't many options in these sizes. When they wear out do you think it would be better to go with a less meaty tire? Will a 225 in the front make turning more difficult?
Thanks!
Welcome, and congrats on the purchase.
1- is the RA1 a track only tire. Not really, they are a good mix tire, track and street. Most people here use the R888r, but the RA1 is significantly similar. In the rain, just be careful. This is an opinion, obviously. I've driven on the stock A048, and R888 in bad rain fall and been fine. I've heard of people having bad experiences on all seasons, just be careful.
2- What are the actual wheel sizes. I have 15x7 fronts, and 16x8 rear, and run 205/50 and 245/45. It's a nice package. I think the stock size (bigger wheel, but smaller width), bites a bit sharper in front, but again, that's preference.
Find out what size the wheels are, and then do some reading on what different people are running. Or, sell/trade those for some LSS or cup wheels, and run the OEM size for a bit.
With tires, there's a lot of good research done, and there's also your preference for "feel." Good luck!
Note that tires 4 yrs old have limited grip. And, hi performance tires often have little grip below 48F.
Tire Rack lists max and min wheel sizes for each tire.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 -35 minutes after coolant has reached full operating temp before engaging cam switchover.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
15. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
1 - 3 of 3 Posts
