Aha! I have experience with this, my turn to shine! :nanner2: Easiest step is to check the appropriate fuse (F22) in the front passenger side hidden panel thing. Next step is to try resynchronizing the fob (remove battery for half a minute, hold both buttons until solid light, then hold A button for 1 second while standing right by the passenger mirror). If that doesn't work then disconnect the battery overnight to restart the ECU. Then reconnect and try resynchronizing (a few times!).
If all THAT doesn't work, then play with the center console button that locks/unlocks the doors, then try everything again.
Hopefully you don't have to reprogram the fob. Good luck!
