After searching in the book
TRIP DISTANCE/DIGITAL SPEED DISPLAY/TIME CLOCK
The top left portion of the LCD panel may be cycled through the following displays:
- Trip distance (in same units as analogue speedometer).
- Digital road speed in alternative units to those indicated by the analogue instrument (either mph or km/h).
- Digital time clock (if fitted - this feature will not be available initially).
To cycle, one at a time, through these three displays, briefly press the small button on the right hand side of the steering column shroud.
(Note that this button also adjusts the brightness of the instrument and HVAC panel illumination if held pressed when road speed is selected).
Trip distance: Units displayed are miles, and range from 000.0 to 999.9. To reset to zero; when the trip function is displayed, press the button on the column shroud for longer than 1 second.
Time Clock Setting: To adjust the 24 hour time clock (if fitted);
- when the time function is displayed, press the button on the column shroud for longer than 1 second. The
hour display will then flash.
It said it can be changed to show speed but does not really say how unless I missed it in the writing lol. I would try on mines but it's still in pieces.
It's worth a shot.
Sent from AutoGuide.com App
