Fishing line worked back and forth like dental floss is great and will cut through the adhesive tape. Then you can just remove the leftover adhesive with Goo Gone or just by using some of it and sticking it to itself to pull up what is left.Yep. I got mine from them a couple of years back and they are legit. The front badge is an exact copy of the stock badge, only in black. Be careful removing the front badge. The tape Lotus used is vicious. A heat gun on low temp is your friend.
Corvus
