I have a fully stock 2006 Exige with a stubborn P0171 Code: System Too Lean (Bank 1). I've searched the forums and found many useful ideas, but still haven't had any luck.
For some background, here is an ad from the original owner back in 2015 with an extensive list of mods. Prior to being sold, the car was brought back to stock. The second owner, who I picked up the car from, said the P0171 code popped up pretty quickly in his ownership ~300-400 miles in (the car had about 8.2k miles on it).
At this point, with most of the main suspects looked at, and since the code popped up so quickly after the car was brought back to stock, I'm thinking the culprit may be somewhere there. I'm not very familiar with tuning, but could the issue be somewhere with the ECU Chip Tune? If the tune was kept, but the SC, exhaust, etc. were brought back to stock, is it possible the ECU is having trouble compensating and throws a code because of that? If yes, would I have to find a Lotus dealer to reset the ECU?
Work done up to this point:
New MAF Sensor
Replaced both O2 Sensors
Replaced O-Ring on the oil dipstick
Repaired a small crack on the exhaust
Fuel Injectors - Cleaned
Battery Tested
Spark Plugs - Cleaned
Air filter - Cleaned
O2 connectors are in their proper place
Any help is appreciated, thanks!
New MAF Sensor
Battery Tested
