1 - 4 of 4 Posts
I'm about to buy new wheels in a few months, but in the meantime for some reason my front right tire is completely worn out. Does anybody know where I can find cheap front tires for my standard Elise wheels?
size would be 175/55-16
thanks!
thanks!
The fronts wear so slow comapared to the rear that there is no real good reason to save money on cheaper fronts... I would stick wth what you have on there, and just replace the one tyre with the same again.
The wear probably indicates you need an alignment though. Do the 4 wheel alignment - because if the front is bad, so too is the rear likely to be off.
will do. I figured alignment was off considering only the front right is really worn, where as the front left seems fine.. thx
1 - 4 of 4 Posts
