1 - 8 of 8 Posts
Happy to join all the fellow enthusiasts here. I’ve already learned a lot browsing the forums before purchasing my ride and now researching things others have encountered with their cars. I recently purchased a 2006 Lotus Elise with just 5,800 miles. Ecstatic about it but have already encountered a couple small things that I’m hoping this community can help solve. Thanks!
Welcome! 5,800 miles is barely broke in! You'll find this site to be an invaluable resource. Post some pics of your new ride. Happy motoring!
Administrator
Welcome to LT and you're lucky to have such a low mileage car! Chances are each of your problems has been encountered before so try googling your search and add lotustalk at the end and you'll find previous threads on it here.
These are wonderful cars.
You are going to have lots of fun.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
These (lube, mods) make a huge change in shifting. I also reoriented one swivel joint.
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
Congrats on the Lotus, I’m not too far from you!
1 - 8 of 8 Posts
