I just installed BOEs baffled oil pan on my 05 elise. When i check the oil the dip stick will not go all the way down without forcing it ( makes a click sound). Doing this indicates the oil level is too high. Now if i flip the dip stick around (the curve facing the other direction) the level comes up too low and requires less force. Obviously the dip stick is hitting something. Is this common? which reading is accurate? or what did I do wrong?
FYI I bring the engine to operating temp then wait ten min before checking.
Thanks
Thanks
