1 - 6 of 6 Posts
After last weekend's track session my Pagids have had it so I figured it's time to break out the CL pads I bought a while back.
Problem is, however, that they simply don't fit in the calipers. The compound part is too massive. I was able to force them in Jeremy Clarkson style (I'll get a hammer....) but wheels don't rotate freely and this will generate massive amounts of heat seeing as a race compound don't wear out quickly....
Has anyone else with AP 4 pots had this happen?
Any tips on what to use to make them fit? Sanding or power grinder?
Discussion Starter · #2 ·
In case anyone else runs into this:
I sanded the pads down until they fit. About 1/20th of an inch on each pad. Works perfectly now. I advice a power sanding tool of sorts.
Iveria,
How do you like the pads? I'm looking at various replacements myself (currently have Hawk). I'm kinda leaning between the CL RC6s and the Carbotech (XP12/XP10 for F/R).
Not having tried any other pad I have to say the CLs are superb. Grips perfectly from cold, excellent brake feel and Even after a 19 lap stint at the most brake-unfriemdly track I know off there was no sign of fading what so ever. I recommend you at least give them a try.
I ws told they would eat my brake discs, but they should be good for at leas another set, possibly two.
That being said I do hear a lot of good things about Performance Friction pads/discs.
At track temps the pads do not attack the rotors too badly, but at cold temp, they chew through the rotors quickly.
I didn't know that, but seeing as I spend 85% of my time with this car on the track it would explain the lack of rotor wear :)
1 - 6 of 6 Posts
