1 - 1 of 1 Posts
My RH Front Intake Grille is very loose and only appears to be held in place by one screw. I'm sure when I'm at speed it is jostling around some. Are these easy to remove and fix?
My side intake grilles are not flush/snug on their ends where they fit. It looks as if they have just warped a tiny bit or worked themselves out of place. When I push the grille ends (at the top and bottom of the 'C') of the intake back against the intake itself and let go they go right back to pulling away from the edge just enough to where I notice its not flush against the semicircular intake.
Is there a way to keep these fitted correctly or are mine just warped a bit and need replaced? Has anyone painted their intakes the same color as the car?
1 - 1 of 1 Posts
