1 - 10 of 10 Posts
My Evora 400 had sat on the dealers lot for a few months before I acquired it and as a result developed a lot of water stains on the OE Lotus clear wrap. I normally do my final rinse through a filtration system to avoid this but now that it's here I'm stumped. So far I tried the alcohol, vinegar and a meguires pre-wash light polish but no luck. May go clay bar next but thought I'd ask the pros here first. Any recommendations on products specific to this? Thanks
Both products recommended for hard surfaces; am reluctant to use on soft vinyl. Will research. On Amazon, Meguiars says to not use on wraps.
It may be best to look at it respectfully and say "thank you for your service" and leave it be. It did its job.
You be the only one that notices and may mess it up more by trying to reach perfection.
A random orbital buffer and a light polish (Menzerna SF3500 or similar) should clean it up no problem. Just tape the edges of the film so they don't get polish buildup along them.
Perhaps if it finished 4 years of active duty but the car has only been on the road for a month.
Less is Better
Maguiers also makes a plastic cleaner product and plastic polish that's meant for use on soft plastics like convertible windows. I've used it for years. You can start off with that and see if it works.
Discussion Starter #9 (Edited)
And very inexpensive on amazon; just ordered, thanks. I would add that the majority of stains are located on what I would call the front quarter panels above the headlights. Perhaps it's an artifact of the crazy light wash system. I disabled that function when I took ownership but for the previous 1000 miles it was still in play.
Less is Better
I wouldn't expect the washer fluid in those to have dissolved minerals.
1 - 10 of 10 Posts
