It's really easy to get to. Remove the floor in the boot. Takes a few minutes but then you can easily get to everything and inspect things well.
David Teitelbaum
My method is use a power bleeder. It pressurizes from the master cylinder side, and unless you drain a couple of quarts of hydraulic fluid you can't run the reservoir dry.
