my clutch is sticking at high rpm's. when i get on it and then push the clutch in to shift it says in and then has a delayed release. can anyone help out i have bled the clutch 2 day in a row and it still happens.
More info is needed. How many miles on the car? Is your fluid level going down. Are there little tiny black bits in the filler? Is the fluid brownish or foggy? Is the slave cyl squeaking etc?
Just a few symptoms of a slave cyl failure. You could check the clutch return spring but that shouldent cause what you described.
Of course the car gnomes could just be out to lunch and not pushing the pedal back up?? dunno?
