22,000 miles. Car is mechanically stock. Never had any issues, am original owner.
Last two months, been having this weird issue with the clutch. There is NO driveability problem, and clutch functions same as it did new from factory.
If the car is parked turned of:
As I depress the clutch all the way to the floor, it almost feels like clutch pedal moves and makes a "clunk" noise. Noise is mechanical and inside the car (right where the pedal is).
Other way to describe it is if you are wearing sandals, as you depress the clutch all the way down, your feet slips off the clutch. It sounds like metal pedal hitting metal.
That is the best way I can describe the noise. I had another Forum member drive the car here and he had suggested "master cylinder or the pedal pivot"
Car does the same when turned on and driven.
Just wanting to see if others have had this issue, before dragging car to the mechanic.
Thanks!!
Thanks!!
