1 - 8 of 8 Posts
Can someone explain the difference between the clutch master cylinder for a pre 1992 and 1992 onward? They look the same. I need to replace mine on a 1988 turbo
The only difference was the size of the bore. Your 88 should have a 5/8" bore and the later models had a .70 bore. Lighter pedal and longer stroke with the 5/8".
You could actually use either but there are different setup specs regarding the pedal depending on which bore it is. Probably easiest to stick with what came with the car and that setup.
Jim
1 - 8 of 8 Posts
