My clutch pedal (it has been isolated to this area) is making an odd noise. Sounds like a cross between a squishy fart (don't ask) and a heavy spring on a door slowly opening and closing...
The clutch travel is slightly "un-smooth." Clutch take up, action, and noise at the clutch itself are otherwise normal. Has been looked at by the dealer, and down here the tech is great and was stumped himself. We tried lubing the shaft going to the master cylinder, which helped a bit, but still hasn't solved it.
I sat in a 2011 Evora S and it made a similar noise. But this was one other car so small sample. Tech and I thought maybe it was a symptom of the heavier S clutch.
As a reminder, mine is a 2010 NA running 2012+ Evora S clutch and flywheel.
It works and drives just fine but the noise drives me nuts. Was wondering if anyone else had experienced this.
I guess between my headers, straight pipe and rattly front brake rotors I shouldn't complain too much about noise, but you know...
