My 06 had been idling rough and throwing all sorts of misfire codes earlier this year after having no problems during the previous year and a half of ownership. I had seen several posts about bad coils with accompanying pictures. I looked at my coil packs on several occasions and they never looked that bad. No sludge, no rust, no moisture, no powdery residue. There were a few brownish/black spots, but it just looked like where the plastic shaft had become discolored due to the heat. I tried all sorts of things to try to fix the problem, but eventually took it to a dealer for treatment.
One of the dealer's mechanics pulled the coils and said they looked okay and moved on to other possible causes. Several hours later, the service manager recommended checking the coils again after talking to the Lotus rep on the phone. Upon closer inspection, the small black/brown spots were definitely burn marks and pitting where there had been arcing and intense heat.
After replacing all 4 coils, the car was like new. Since the coil failures were so gradual, I hadn't even noticed the extent to which the car's performance had suffered. Still not sure why all 4 coils had some degree of arcing after only 12,000 miles. The car is garage-kept, rarely driven in the rain, and I take care to cover the engine during washing.
For anyone else's benefit, below are some pics of one of my coils. The first is the coil itself. Looks pretty good, right?
The second shot is of the "primary" arc point near the top of the coil. I have removed the rubber O-ring around the top for better visibility.
The third photo is of a very small arc point near the bottom of the coil shaft before it starts to taper down. I point this out because on each of my coils there was a top arc mark and a corresponding lower (but smaller) arc mark. (Electrical entry and exit points?).
The last photo shows these two points in one photo. The top and bottom arc points were always close in a line with each other.
As mentioned above, after replacing the coils, my P1301, P1302, P0300, P0301, P0302, P0303 and P0304 codes virtually disappeared. If anyone has been having misfire problems and their cams and rockers look okay, it may be a good idea to look at your coils closely. This taught me that the coils don't have to look horrible to be failing.
