1 - 6 of 6 Posts
Hi
I'm interested in converting a S2 111S from RHD to LHD. I've moved to Poland and used LHD cars are far more expensive and there's not much choice. It's impossible to register RHD cars in Poland.
I've contacted Blacktan who's done it successfully. I'm interested in hearing of anyone else's experience in this - any problems etc.
Thanks in advance!
Jez.
Hi Jez ,
I think is a litlle bit difficult to find here people that have already made the conversion ...
Generally and in public this is a simple (for a specialist) modification and the only parts that you are in need without any other discussion is STEERING RACK and wiper mechanism ..
You are using the same steering column , same pedal box , same brake servo , same wiring ...
You need also a new RH gear level surround , one RH adjustable seat railway , and some parts from RH dashboard .
Good luck !!
Super Moderator
Hi Jez ,
Good luck !!
Do you need to change the wiper mechanism - or just where it parks?
I think also the upper aluminum beam where all the dash and stering rack are attached is also diferent and may complicated to replace
1 - 6 of 6 Posts
