Sorry, but I don't get it. If red is the braking zone, why would you want to be braking there? You're already through the turn.Having had no luck googling this potentially life-saving maneuver, I am going to try to explain it myself. I’ve done this before, with varying success. And, as you’ll see, I am terrible at diagrams on the computer. (Anyone who can find/present a better demo is welcome to.)
As we all know, in many cars and especially those with mid-engines, we don’t want to lift or brake in a fast turn.
But, if we go in too fast, we miss the apex, someone blocks us, or some other emergency arises, what can we do?
Well, we can use the (Stirling) MOSS EMERGENCY LINE. SM says to drive straight as far as you can, while braking as heavily as possible. You will lose enough speed to get the car under control before you have to turn (usually at the far side of the road). Remember, cars brake very quickly, more efficiently than they accelerate.
I’ve used this many times on track and street and I can tell you that it works.
Red (if it shows up) is the braking zone.
Many on ET really know how to drive (better than I) and comments & suggestions are welcome.
But, I hope this helps you as much as it’s helped me.
I dunno. :sheep: While straightforward (har-har), you need to remember that SM's advice comes from an era of cars without ABS.
If you have ABS disabled (or non-existent, as in a race car), certainly SM's expertise would apply. :bow:
If you have ABS enabled, you can add a bit of trail braking to the mix. But it all comes back to stopping ASAP and limiting upset to the car as much as possible.
Contrary to popular belief, ABS is not an anti-ice braking system.Nor does it allow a car to stop shorter.
Pulsing the brakes allows you to STEER while braking, whereas if your brakes were locked-up, this would not be possible.[/QUOTE
That's a really good point, but I can even lock up ABS-assisted brakes in track applications when I'm in panic mode (when I'm making this face). Once they're locked up, it's good (but difficult) to remember front tires don't steer if they aren't rolling. Then the Moss line is your only friend...and a neck brace if that doesn't work out.
Tom
Yes, but as you say you can't break the laws of physics with ABS... the tires have only so much grip and the sum of braking and cornering forces can't exceed this... in other words, if you're turning, you can't brake at maximum efficiency and if you're braking, you can't corner at maximum g's.I dunno. :sheep: While straightforward (har-har), you need to remember that SM's advice comes from an era of cars without ABS.
The ABS has no direct ability to prevent a spin in the first place.If someone puts in too much steering input while hammering the ABS, it's likely to increase both the stopping distance and the radius of the turn (or even exceed the ABS's ability to prevent a spin).
That's certainly true for most types of ABS... I was implying ABS + stability control, which does have some ability to prevent some types of spins.The ABS has no direct ability to prevent a spin in the first place.
