1 - 1 of 1 Posts
Well I received notice to have my Emissions tested on my Mercedes. Apparently the emissions test is 100% dependent on the OBDII reading. They just want to make sure that the O2 sensor is working and no check engine light. There was no visual inspection either. So I guess that means if you did a D-Cat in CT and have a fix for the check engine light and O2 sensor, you should not have a problem in CT.
1 - 1 of 1 Posts
