1 - 20 of 26 Posts
Just got my long awaited 3 piece wheels from Kodiak Motorsports in Canada; very nice quality racing wheels.
I was a little concerned with the fit since I had to take all the measurements myself (caliper clearance, front and back spacing, centerbore etc) but they turned out just as I'd planned. The rear 17 x 10 inches weighed in at 18lbs.
Pricing of around $2800 for 4
i dont wanna sound like a vulture, but do you have your old wheels still? would you be willing to sell them?
from his other thread:
Still blows my mind sticking with a stock width front tire.
thanx AJ
hmmm custom wheels, i woulda went with 16x7 and 17x8 maybe x9 so i can keep it under the "stock" body
btw: just sent Kodiak an email and some questions...stay tuned LOL
looks good tho, cant wait to see it put together
Sorry, the old wheels are long gone!
thanx AJ
The fronts are stock 16 x 7 and fit under the stock fenders; the rear need arch extensions or a custom rear clam. I'll go with arch extensions this season and then widen the clam when I have it made out of CF next winter!!
You could sqeeze a 9" rim under the stock body if you take up all the available backspacing. I chose to pull the inside of the wheel out about 10mm since the stock size tires were rubbing the frame slightly under extreme load on slicks last year.
Discussion Starter #10
This was the recommended track setup from Lotus Sport UK; basically the same setup they used with the lotus cadena cars when they won the UK GT3 championship. Speaking with the engineers over there many times, they found the fronts were underutilised and more rubber was needed out back.
thanx for the 411!!! i emailed Kodiak and waiting on a response :up:
Discussion Starter #14
Kodiak are very good to work with and you will most likely be speaking to Daryle, the owner, who is very knowledgeable and helpful.
I have to make a correction; the fronts are 16 x 7.5!
yes Daryl emailed me back, got a quick price quote as well, if my Volks dont come in anytime soon, ill just order a set of these instead i like the RT model
16x7 17x8
thanx again
Discussion Starter #16
Here's a couple of pics of the car on it's way to be reunited with it's new motor. The wider rears really show the camber more; around 2 degrees negative in my case.
some serious rubber!!!! Did they say if it was just the lack of weight in the front that didn't utilize the front tires? Seems like the the downforce they have available they would be able to make better use.
Either way I'm jealous of your project. Should be a killer.
HOLY camber!!!
By the way, those things would look amazing powdercoated flat black.
Discussion Starter #20
What they said was that the stock sized tire was more than adequate and estimated that it was only about 75% utilised in their setup compared to the rears. It was my experience also last season that when driven to the limit the car will lose traction at the rear; the front just went wherever I pointed it and it didn't matter if I was on the power, off the power slow or fast corners the car wouldn't push. That said, before I added 1 deg neg camber up front it was a different story.
1 - 20 of 26 Posts
