21 - 40 of 94 Posts
shay2nak
Does Burger King still give out those paper crowns? Wear one of those while you're driving. rotfl
because racecar
Discussion Starter #22
That would actually be pretty amusing. Chances are I will remove their stickers at least from the back window
Vendor
We expect that kind of class in XP, you can leave'em on in SSM though. :p
Be VERY careful with Chris Barrys AC kit. The bracket allows the stock Rover AC compressor to be used, which is all fine and well, but it uses a TINY daihatsu charade alternator, i think its around 45 amps, IMO no way NEAR enough to drive even a stock engine. The stock alternator on the k20 is 100amps.
Now, I am an electrical engineer for an automotive OEM, and 45amps is stupidly small, you will be running on the limit by simply switching on the headlamps and if i remember doing my calculations if you had the high beams switched on; the battery would no longer be charging. This is on a stock engine stock chassis setup.
Think about how much more current than stock simply your pumps are drawing. Anyways, I rant.....
Chris is a great guy and very very helpful, but on this point I totally disagree. If you could get a daihatsu charade alternator built to at least 100amp spec then it would be great IMO
because racecar
Discussion Starter #27
Good to know. I will find out how much alternator can fit with his kit. As it stands I haven't ordered it yet. Do you know of any other options?
I may end up just figuring out some solution myself.
Considering I am going to be running four 300lph+ lph fuel pumps, pumps for the air/water, and an aftermarket head unit and sound system, HIDs and probably some other stuff that uses more juice than stock I don't think 45a would get me very far.
To be honest, the AC compressor idea is actually very simple, it basically mounts the AC comp directly in place of the alternator just using a simple H pattern bracket to adapt the different bolt pattern, and uses a couple of small arms to hold the new alternator down stairs next to the sump. IMO i would just live without the AC.
Also, forgot to mention the daihatsu alternator is a couple of ribs smaller on the belt, another thing I did not agree with but its not so bad (I was worried about running superchargers).
because racecar
Discussion Starter #30
Inactive
Clutch: You can play around your whole life with high load twin disks than put so much load on the crank that you spit out the thrust bearings (I've been there with multiple clutches, including the clutch master). Or you can bite the bullet and get a carbon / carbon twin disk with stock pedal pressure and 840 lbs torque rating. I've had zero problems with my Tilton in 8 years. Beware clutch manufacturers who don't know torque from power.
AC: The standard compressors works. There is a very simple top bracket and a reasonable bottom bracket. Once I get access to the drawings for my engine I will post them.
Alternator: See above. Keep stock alternator.
because racecar
Discussion Starter #32 (Edited)
Certainly interested in your drawings for the brackets. If the solution fits for my implementation I will have them or something similar fabbed.
Carbonetics was possibly next step but the clutch masters is feeling OK. Competition clutch was a leg breaker. Did you have some problem with the clutch master twin disc specifically?
Inactive
Previous engine, but the clutch master wore out the crank thrust bearings in a matter of months. Carbon is fantastic because it releases as soon as it gets 0.001" clearance, and the coefficient of friction goes up with temperature. Only downside is the price...
Nice build, thing will scoot. In for updates!
- Andy
because racecar
Discussion Starter #35
Looks like from your advice and some looking on the k20a forum spring pressure on the clutch pushes the crank into the thrust bearings and grinds the crank. Looking over the k20a forums it appears this has happened to a few people there as well.
Appears proper adjustment of the clutch master cylinder and pedal are a big deal in preventing this issue, and a clutch stop would be a very good idea also.
I guess you adjusted everything and still had issue?
Inactive
It's just that the crank trust bearing is small, and it just can't cope large amounts of end thrust on the crank. The pedal adjustment is only an issue if the clutch release is bottoming out, which you can normally feel as the springs go over center.
The #1 thing to do is to disable any clutch interlock and never crank the engine with the clutch disengaged (ie pedal down). If the thrust bearing is overloaded then cranking with zero oil pressure is going to make it really, really, unhappy.
In my opinion any clutch interlock should not allow cranking unless the clutch is up (not down), but the lawyers don't see it that way. My Elise didn't have an interlock - I think only Canada models did.
As far a clutches go, the Exedy Hyper Single handles about 4 time the torque that Exedy claims. From there the Tilton twin plates are good, but the Tilton carbon/carbon is the best (rated at 840 ft lbs, available in 540 ft lbs too).
re: Clutch
+1
I like Tilton C-C clutches. Every few years, I look at their drawings of a 5.5" triple CC clutch and call them to see, if it will fit into a K20 bellhousing.... It does not!
7.25" double works.
I got an ATS clutch and adapted a Tilton hydraulic throw-out bearing. Took some playing with piston length... Based on ATS clutch and the extra long piston I had to get, there should be room for a 5.5" triple!!! :)
Pedal stop is not a big deal either way...
CC clutches are the greatest.
Many years ago, I had many problems with metal clutches... Switched to CC and everything worked so well and lasted forever... and cost a small fortune...
Anton
because racecar
Discussion Starter #38 (Edited)
Tuning is done. Here is a kill mode dyno plot.
This is all the MWR/FIC 1650cc's will do at 90% with E85
757whp
536wtq
31psi
21 - 40 of 94 Posts
