1 - 6 of 6 Posts
Hi all,
Just wondering if this had happened to anyone and is it possibly the starshield peeling off with paint on its own or a small object strike while driving?
There appears to me no damage like a dent or anything, but it would seem highly unlikely that the starshield would peel off so suddenly like that.
Thanks,
Oliver
Red Automotive lighting Automotive exterior Motor vehicle Vehicle door
He's on fire!
well of course its a rock. take a look at the starshield right in front of the rear wheels if you haven't already...
Ok thanks, I took a closer look and do see a couple of really small ones where you said. Ugh first one (and it had to be big) on the front to break through the starshield.
2008 Exige S240
That looks like a crater on the moon.
It may be too expensive to fix than it's
worth.
I would cut around the crater with a razor blade
and touch it up.
He's on fire!
touch ups are always pretty obvious. Doing a touch up as you described sounds like a great way to
- put razor blade cuts in the paint
- increase chances of pulling off paint if/when the starshield is removed at a later date
If you're going to fix it, remove the entire piece and replace it.
Gamera The Atomic Turtle
lucky it did not hit a headlight and crack it.$$$$
1 - 6 of 6 Posts
