21 - 23 of 23 Posts
Discussion Starter #21
It clips at 100 because that is the largest value. His labeling is confusing - "throttle" is the pedal, and the "auxiliary" is throttle. In post #11 you can see where he lifts briefly but too quickly for the ECU to respond. This is due to a filter, PID loop, and lookup tables
The missed lift of throttle by the ECU is not a lag problem. I did some measurements on the graph and 50% pedal creates 100% throttle. The lift you refer to was still above 50% pedal.
Later,
Eldon
I didn't say it was a graphical clipping. Your realization that 50% pedal creates 100 (no-unit) throttle just emphasizes what I think I'm seeing. There's no lag that you'd expect in a PID algorithm, just a scaling of values. How are you logging "Auxiliary 1"?
Discussion Starter #23
Dan,
Both the pedal and throttle position are being read from the ECU via the OBDII/CAN port. The numbers being returned can only range from 0 - 100.
I will check the data logger to see if it is scaling the response correctly. The manufacturer of the data system wrote the decode for the CAN bus message.
Later,
Eldon
21 - 23 of 23 Posts
