Ok so here is the skinny.
Over a period of ~3 days my AC went from working to intermittent to nothing. It appears I have different symptoms than most others with the common AC problem.
Blower fan works on all three settings.
Heat/Cool knob appears to work fine. As in it gets hot when I turn the dial clockwise.
AC button lights up and I can actually hear the AC compressor kick in sometimes.
Condenser fan does seem to be working too.
Checked the refrigerant pressure on the low side and it appears to be in spec.
I dont have a tool to check the high pressure side of the system while in operation.
What do you guys think? Could I have a compressor thats gone bad? It stopped working at only 10K miles and since this is the toyota unit I assume its probably not the cause.
