1 - 2 of 2 Posts
Does anyone have a short info how big the Oil & Water Lines are that go through the side sills?
And maybe the OEM used fittings? are they BSP or JIC (DASH) ?
I want to upgrade my cooling system and get all the right fittings before i remove the old ones ;)
The oil lines for the coolers are 5/8", or 16mm. The water hoses that feed the radiator are 32mm, but through the sills, it's an aluminum tube. . Then there are the water lines that feed the heater core, can't help you there. :smile2:
1 - 2 of 2 Posts
