1 - 14 of 14 Posts
hi for a 2008 exige S240 (not sure if this is different to elises of same year)
Have searched around a lot and can't seem to find evidence online for a display meter utilizing OBD2 or ECU signals to show parameters monitored by the car from factory.
I called up the manufacturers of these displays and one asked me if the car was manufactured after May 08, as it would be on the CAN system. Then I searched forums here that had the "CAN" word but some threads were from 1-2 years ago. Another manufacturer replied "elises had problems but the new ones should work", citing also that he thought the ECU's were the same.
Found some products. If anyone has experience, please share.
Thanks.
http://www.dashhawk.eu/detail/screenshots.php
http://www.racelogic.co.uk/?show=-CAN_Design-CANDisplay
http://www.scangauge.com/support/CompatibleVehicles.shtml
http://www.brockwayengineering.com/
http://www.nengun.com/trust-greddy/intelligent-infometer-eco
http://www.racinglab.com/apexi-407-a902.html
Post 2008 all the cars use a new OBD II CAN bus system, previously to that the cars used a proprietary CAN bus which is incompatible.
If the device says its 08+ OBD II CAN compliant, it should work with an +08 car, but i've not actually tested one, CAN is a lot better than the old OBD II stuff, so it should have less compatibility and timing issues.
Of course you'll still only be able to read whatever PID codes it supports, which typically hasn't been that many.
Charlie - will the Mongoose still work on the '08 model?
Here's another system, info on compatability are only for USDM but I sense Lotus might have been ignored even if it was compatible.
http://www.nengun.com/hks/camp-2
similar to dashdaq
good system (if compatible) for those with rear view monitors already.
similar to dashdaq
Nice... I have the JVC headunit w/ DIN sized monitor and A/V inputs... so this would be a nice space savings. Does it log too? Removable memory?
Discussion Starter #13
I've been thinking about getting this..
It's just about the perfict size to fit in to the stock dash location too...
http://www.aimsports.com/products/mxl-chooser.html
IMO, AIM is nice for track.for street, I dunno especially when the OEM dash is a stack. And I don't think they are the easiest systems to rig up. Saw a youtube clip of komotec car and i think it had AIM mounted to the center of dash.
The 08+ dash cluster is updatable, but I can't remember the functions dealer told me about.
Discussion Starter #14
thanks charlie
Getting some conflicting info or may be Im just confused.
I contacted brockway and tech there told me:
> The OBD2 parameters are listed on our website. The parameters are a
minimum that must be supported in order for Lotus to comply with OBD2
regulations.
http://www.brockwayengineering.com/r920.html
Quite a few parameters logged here.
Another sales tech (from which co. i forgot) said cars made in May 08 and on will be on the new OBD2 CAN system. My car is being delivered May so if this is true then I'll need to find out whether I made that cut off or not.
Is there any way to find out other than asking the dealer?
Thanks
1 - 14 of 14 Posts
