1 - 5 of 5 Posts
is the O ring a different size from stock the the BOE dipstick? Seems that I'm getting massive blow out from the hole in the block and my O ring was flat and hard. Time to replace, but not sure the size specifics. Anyone Know?
2mm thick - 10mm ID worked for me. Autozone 99 cents.
Pain in the ass to change, if you are SC you cant get the tube all the way out, but it will drop down enough to change it from underneath.
ended up pulling the SC since I wanted to change the intake gasket and re-gasket the block off plates for good measure. Hoping I can get the car back together this weekend and get a drive in before Father's day!
1 - 5 of 5 Posts
