1 - 15 of 15 Posts
A large area of my driver side seal panel is discolored. I've tried Mothers Back to Black and if anything, the lighter areas show up worse now!
I suspect that some kind of solvent was spilled on to it at some point (before I bought the car).
Anyone got any ideas how can I restore it, given that Back to Black won't?
p.s. And no, I don't want to replace them with CF!
See any guys with CF are willing to sell you their OEM pcs?
If they are leather like the Evora, you may try to re-dye them.
I have used Leatherique products for years, including their leather dye. I had them color match some for a street rod I was building and sprayed a console and steering wheel with an airbrush and it matched perfectly. Here's a link: ORDER Products | Leatherique Restoration Products
Their leather Rejuvenator is also fantastic and I have used it on all my cars for years.
The sill is plastic, not leather, so I'm not sure Leatherique is necessary. Plastic dye could work just fine. I got a can of black dye from Amazon just by searching, dabbed it on with a cloth and my sill looked like new. It wasn't as bad as yours but they had spots and visible scratches. I did it when I got my car, about 4 years ago and the sills still look fine. It was only about $20.
I wasn't sure what they were made out of or if they were covered. But since they are plastic, please disregard my suggestion as I don't think Leatherique will work for plastic..
Maybe you could paint them with a good plastic compatible paint or wrap them in matt black vinyl , but the plastic dye sounds cool but not seen it in person.
www.theapexinn.com
Try some leather dye.
Discussion Starter · #9 ·
I got my plastic dye (ordered from Amazon) on Sat and used it. It comes with a cleaner that you use first (after diluting) that removes silicones and other surface treatments first.
After one coat, the discoloration is almost totally gone. I can still see it, because I'm looking for it. I think a second coat should make it completely disappear.
Thanks for the tips!
you try a plastic "restorer" by chance? when their is hazing on exterior plastics, it will clear that up
Discussion Starter · #13 ·
I tried Mothers Back to Black and if anything it made it worse. The non-stained areas got darker, but the lighter areas stayed the same. So the overall contrast increased.
Less is Better
That's the one I got.
It's cool stuff and that little bottle goes a long way. I found that if you apply it with the sponge alone it dries very streaky. If you apply it and then run a rag over it while it's wet, the results are really nice.
Discussion Starter · #15 ·
Thanks! I'll try that for the next coat.
1 - 15 of 15 Posts
