1 - 11 of 11 Posts
So my lights have been looking pretty bad and everything else seems to only last a month, so I decided to sand them down from 1000,1500, then last 2000 grit sand paper. After that I layed down 3 coats of clearcoat. Spraymax 2k. 2 part uv clear in a can. Hopefully this will last a few years. Here are some photos how it came out. Didnt polish or wet sand after the clear, dont think it needs it. Lmk what you think!
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
I also did this a month ago. I hit it with 600, 800, 1200, 1500, 2000, rubbing compound, then polishing compound. I also sprayed with 2k clearcoat spray then hit it with rubbing compound then polishing compound after. Looks better than new now and it has a color shift hue that looks really good. The 2k spray is autobody grade spray with isocyanates so make sure you wear a respirator. I figured since clearcoat on cars last 10+ years, I should be good till then. Probably even longer once I apply 3M clearbra on it. Took me 8 hours to do everything.
Did you sand it by hand?
Wow Such Admin
I wish I had krypton green!
I used the 3m headlight kit and they came out nice and clear as well. Although it took me a bit longer than 30 minutes a side.
Yours came out great though.
Fred, it looks like there is some orange peel on your lights. What I did to get rid of them is to sand lightly with 2000grit until you see the low spots are gone. And then hit it with 3m rubbing compound then meguires scratchx. It will looks smooth as still water after. Becareful not to sand too much with the 2000grit. You just want to level the clear coat.
1 - 11 of 11 Posts
