Hey guys, I just replaced the serpentine belt on my Exige because it was making a chirping noise. I think Lotus recommend that these be replaced every 2 years. I thought that it would be helpful if I made a video incase you guys want to do it too. It's pretty easy and won't take you longer than 45 minutes your first time. I used a 75.5" Gates belt which I paid $30 for at O'riellys. Your belt may be a different length depending on your configuration.
You are going to need a long breaker bar or a ratchet with a hollow pipe for leverage. Also you need to use a SIX POINT socket either in 19mm or 3/4". You will round out the nut if you don't use a six point. When you compress the tensioner, it will retract SLOWLY. So just apply constant pressure and it will get there. It is much easier to get the belt back on with another set of hands. Good luck!
