1 - 20 of 71 Posts
I don't really care for most of the side sills that are available. Most are too large for my taste; looking more like running boards.
So, I decided to make my own...
I made a cardboard template following the body line of the car, made a CAD drawing from it, and had them laser cut out of .100" aluminum. Cost $100 to have them cut, including material. Not too bad.
I painted them with Plasti-Dip and installed them with Rivet Nuts.
I attached the .dxf file if anyone else likes them and would like to make their own. They fit my 2010 Exige S240 like a glove. No guarantee they will fit your car, but would certainly give you a good starting point.
** The Enforcer **
They look very similar to my Reverie carbon fiber side skirts.
I agree that some of the side skirts are very large. I've accidentally touched my foot to my side skirt exiting the car. I'd have to make a very deliberate exit if I had the APR or other large side skirts.
Nice of you to post up the specs for others.
San
Closer than you think
Great idea and execution! I wish someone would make a similar CAD plan for the Elise. That way we could purchase the plan and take it to a local shop to be cut.
What thickness of aluminum did you use?
** The Enforcer **
.100" in the first post.
San
Very nice looking pieces. I hadn't thought of making a set for my car, but now I think I will! Which rivnuts did you use?
Thanks!!!
When I pick up my Exige this week this and a difflow diffuser are first on the list. Do you have a close up of the edge of the sill? I would like to see how thick .100" looks. Do you think a rubber edge trim may finish off the edge nicer?
Thanks again.
Discussion Starter #10
I rounded the outside edge with a sander before painting. I also did take a 3/16" ID fuel line that I had lying around, split it and stuck it on the edge to see how it looked. That looked fine as well.
For those of you looking to do something similar to this and want edge trim I have found this to work quite nicely.
Good work OP they are subtle, but look very nice.
Rubber Edge Trim 1 4" Opening | eBay
Stupid question... Where do I take that .dxf file to have those made?? Should I just google metal fabrication shop? Or does it need to be a auto specific place?
Very nice. Thank you for contributing to the community with the download.
Discussion Starter #19
Any shop that has a waterjet or laser cutter will be able to read a .dxf file. I used these guys:
Discount Steel
Jason Merrell
Texas Inside Sales
(682) 730-3008
They were actually cheaper than any of my local shops (even with shipping cost).
1 - 20 of 71 Posts
