1 - 12 of 12 Posts
Hi Guys,
I was wondering whether any forced induction setups for the Elise will have tailpipe emissions within CA limits. I know that the CARB inspection guidelines fail you for most intake/exhaust mods, but say that I had a blind mechanic who could only smell what's coming out of the tail pipe - is there a setup which he would pass? :D
ForcedFed told me their kits will pass the tailpipe test.
The katanas will pass tail pipe emissions tests and OBD II readiness codes (needs the latest flash for the 2006+ models ), no check engine lights either.
They will not pass CARB since they're not stickered and the CVN is different.
Calibration Verification Number
Every modern ecu has a value thats computed from the cal tables, the OEM ones are in some big government database so when you go for a smog they're supposed to connect the car to the state computer and it uploads the information to them, instantly telling them your ecu is not stock.
I have never heard of anyone actually acting on it, but i have seem them attach the computer that records it, regardless of whether they do it or not, thats the law.
Here is food for thought.
This guy in SoCal had a 00 Civic Si. He had the car Bar'd as an alternative fuel vehicle (diesel). I do not know how. But the fact is that NO smog checks required. He had a RSX-S engine swap..
EDIT: HE WAS NOT RUNNING DIESEL IN THE RSX MOTOR!!
I believe there is a way to do it with propane.. Propane has a slightly higher octane rating then gasoline.. I believe somewhere at 103-105.
This is just ideas to explore to avoid smog related questions in california.
$200 and you can pass any Smog test. Helps if u speak spanish too :)
Charlie, do you know if the Gov't receives updates to this CVN when a car manufacturer releases an updated "Flash" relating to engine functions?
I dunno about that, isn't it hard to fake OBDII tests? OBDI is a joke and can be done with you sitting at home.
From what i hear.
1 - 12 of 12 Posts
