1 - 20 of 23 Posts
I can't stand when they do this. When I had my last lotus I always ended up with pads that were noisy. I need new pads!!
Mine do a little when they're cold. Doesn't bother me.
Disciple of Chapman
mine do and I HATE it.
nothing takes the cool factor down a couple notches like pulling up to your stop with a high pitched pig squeal.
plan to change mine in the spring and add some copper grease behind the pads to quite them down
Yep yep yep. 16k+ miles and still do. They do - that is what you get for having nice pads it seems.
I posted the exact same type of thread - got no sympathy from anyone, just some "shut up and take it" messages.
Meh - worth it in my opinion.
Such Administrating
This happens with more performance oriented brakes. One of my friends has a 328i with the bmw performance brake kit with the bigger calipers and such, and his brakes squeal like crazy.
likes to drive fast
One thing I did to reduce or eliminate the squeal is clean out the brake dust deposits from the cross-drilled holes. Take a wooden chopstick or similar, and start "poking". Make sure it goes through the depth of the disc
I would have preferred slotted discs for this reason.
Actually now that I think about it, yes I did that a while back! LOL
I guess that's what did it.. You know what works really well? air duster cans with the red straw on them. you get really close to the drill holes and it blasts right through and push the straw through the other side. Blast out all the dust in the vents too as well as the brake pads. So much dust eliminated, vastly improved cooling.
Unless you have multiple cans, you'll have to do them one wheel at a time in each session, as the cans lose pressure from the temperature drop.
I'll try the duster can method.
I find mine squeal only when I am too gentle, you know when I drive like a 80 year old grandma. However when I drive the car like I stole it - no squeal. Go figure.
Porterfiel R4s are quiet, but the initial bite is pretty poor... as in freakishly no friction... And in the rain I had no brakes at all...
I would stick with the Ferodo DS2500 based stock Evora pads, and just make sure they are clean by stopping hard once in a while... Don't drive like a grandma (glad somebody else said it)
Mine squeeled after a track day, had to replace them. Spirited street driving is fine.
Never once.
Air Compresssor
An attachment for your air compressor - needle valve for basketballs, etc. might be better than cans?
1.Don't breath the dust!!!
2. Try doing a few aggressive 100-10 stops. Gets rid of the glaze caused by babying brakes.
Frankly when i pull up to a light and brakes squeal, I'm happy cuz that means they're serious brakes.
Discussion Starter #18
This sounds like fun! Can I do it between stop lights????? Pweassse!!
MOre fun hitting the exit ramp at full song then standing on them!!
I just swapped out from OEM pads to Ferodo ds2500s and had my rotors ground on a procut machine to get them trued to the car. With brand new pads, clean rotors, they didn't squeal but made a very noisy grating sound until I got to wear I could bed them in. Bedded them in, let them cool for awhile, hit the road. About a week later they started squealing again like the OEM pads. They do seem to be very temperature sensitive when it comes to noise-on a hot day they don't really squeal. Below 85 degrees they do a lot more unless I'm more aggressive wiht the pedal.
1 - 20 of 23 Posts
