1 - 10 of 10 Posts
Hi guys, does anyone using the Sparco bucket seat in the elise? I just wondering how much is the rail for the elise and where can I get it? Thx!!:)
Cheers
Ching:D
Can't you just contact Sparco and buy it directly from them? Usually about $100-135 each... :eek:
sparco rev seat that get trimmed up.
kurt at hypersports makes the brackets you need.
Details, man, details!
-poke-
Call Hypersport to get the exact details. But, a Sparco Rev fits the Elise without modifications. The only place that I know of that makes side mounts (not rails BTW) is Hypersport. Note that the Rev is their smallest seat and it is VERY narrow and the harness belts are too low of anyone over 5'8" so you have to have them enlarged so the harness is at the proper hight; especially if you use a HANS.
There is a simolar Recaro seat; I believe Hypersport sells the side mounts for that as well.
Thanks - it should fit me just fine then!
:up:
So I have this setup and it is not bolting into the stock locations. The new combo is off by about 3/8ths of an inch. What could be wrong?!
Not the admin anymore
Using the wrong set of holes on the floor?? :shrug:
hahaha if it were only that simple.
It's off by 3/8th inch. Is it possible to just drill and tap that one hole into the floor? Is it safe? Or should I just tap it and run the Sys pack from S111?!
1 - 10 of 10 Posts
