1 - 4 of 4 Posts
has anyone used this device on their Lotus Elise? if yes, does the OBD II scanner functionality work well on this device for pulling codes from a Lotus ECU?
[ame]https://www.amazon.com/Automatic-Connected-Realtime-Diagnostics-Detection/dp/B01JRBQ9PC/ref=cm_cr_arp_d_product_top?ie=UTF8[/ame]
last entry shows how to search, so enter the name to see if it's come up.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
For street cars, consider removing one or both oil coolers. Some cover them.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
He's on fire!
Do you need all the functionality in this device to warrant the high cost? I've got a $15 obdii reader off ebay and torque pro app, and I can pull any PID I want and wirelessly log it to boot. It doesn't have the "trip tracker" function, but if I wanted that the only person that drives my car is me, so theres an app for that too.
2005 Elise LSS Saffron Yellow
The only even slightly weird OBD thing about an Elise is that the '05 models use the VW/Audi standard ISO 9141-2 method to get performance and fault data out of the ECU into a scanner. Most scanners try CANBUS first which is only used to communicate with the dash display. Not so good if you want to talk to the ECU about itself or the engine.
So the scanner needs to either figure out to or be told to use the 9141 protocol.
Newer 'Black dash' cars all speak CANBUS natively, so everything is just like 2004 or newer Toyota, etc.
Life gets more interesting if you want to talk to the airbag module, or do any of the custom Lotus things like actuate the ABS module for brake bleeding. But basic diagnostics and performance data are available with just about any OBDII scanner that will talk to an early 2000s VW successfully.
1 - 4 of 4 Posts
