As it is happening on both doors I conclude that it is a CDL module intermittent issue.The alarm system signals the CDL, so that is an outside possbility too.
Cheers,
Michael
Cheers,
Michael
Any idea of where that is mounted on a EU spec right hand drive car? This all started after about 2 weeks of rain and high humidity, so it's possible there is some water, moisture or oxidation in there that's wigging it out. It does seem like maybe it's trying to unlock the doors when it should be locking them so that could be the issue.As it is happening on both doors I conclude that it is a CDL module intermittent issue.The alarm system signals the CDL, so that is an outside possbility too.
Cheers,
Michael
I'm gong to try to mess around with later on this week. Once I've figured out what the issue is I'll be sure to post it here... Hopefully somebody else will chime in that's already had the problem.. :wave:I am having the exact same issue. 2005 federal Elise, no locking problems until last week. Pressing the lock button on the remote or center stack will wiggle the lock plungers (up, almost like they are being unlocked again) but not lower them to locked position. Repeated presses will arm/unarm the alarm and immobilizer as it should but the lock plungers never go down. Operating the plungers by hand works fine. (Once locked by hand, both the remote and center button will unlock the plungers.) Dragon, please let us know if you find a fix.
Hmm, I'll have to check out my sitting battery voltage and clean the terminals. I do get some water in the trunk every now and then. Will try to knock that out tomorrow.I had a similar problem with my 1st Elise. Turned out the batter just didn't have enough juice. Once I swapped it out, the problem disappeared. Apparently it takes a nice amount of current for the locking mechanism to lock.
I would bet it would be more of an issue with the current being put out, rather than the voltage. That would explain the partial lock attempt and why it stops after 10 times or so.Hmm, I'll have to check out my sitting battery voltage and clean the terminals. I do get some water in the trunk every now and then. Will try to knock that out tomorrow.
Sweet... Nice to see your still alive since the post currently under this one says "Viper may be dead"... LOL
Thanks for the link.. :wave:
It's a circuit board with a chip on it and two relays. When the alarm is triggered it sends a low power voltage pulse to the CDL unit and the CDL unit then pulses 12volts power to the door lock solenoids. One relay is for the lock and the other is to unlock. I believe the lock / unlock is just the unit reversing the polarity of power to the solenoid. I didn't take the time to really trouble shoot the unit, but just went ahead and ordered a replacement. If you can hold out a bit for mine to come in I'll report back here as to if it fixed the problem or not.I'm not familiar with the CDL unit, but it requires replacement when it stops working? No connection tightening or realignment, etc.?
Please keep us posted on how this turned out. I just developed a problem identical to Bob Dz.'s today. The doors lock with central locking button and remote, but won't unlock with either.
