1 - 15 of 15 Posts
I had to replace my door handles. I found a few links on the forums here about using some window back silicon stuff but its came off twice now. When the handle comes off I can see I made a nice surface bound but it is not holding. Plus it's very flexible, the stuff that was on there was rock hard.
Does anyone have a recommendation?
I used 3M double sided tape.
Ahh, that strong thin stuff?
See here:
I just did this recently so not yet sure of durability, but guaranteed to remove easier!
2005 Lotus Elise
I used 3mm double sided tape and they have not come off after about 8 months.
I mimic the others in here, just used some Scotch double sided outdoor tape and it works out great, no issues here and I did mine a month ago.
Tape was simple, no mess and theoretically easy to remove when/if needed. At least you have options...
This is what I used for my CF handles. Wanted to be 100 percent permanent and not have to mess with tape. I highly recommend (and so would the tiger king).
U-Pol Products 0727 Black Tiger Seal Adhesive/Sealant - 310ml Cartridge https://www.amazon.com/dp/B002SQY852/ref=cm_sw_r_cp_api_i_PkyyFbE6HR9EX
Yeah so this is the stuff I used now twice, it makes a good bound to the car. The issues are 1) its rubbery when cured, 2) it does not bound to the new plastic cup. I still have some if anyone can tell me how it should be used. I apply it, push down the cup, and wait 2 days before use. Came off twice now (two applications). Each time I removed all the excess.
Maybe my experience was different because I was bonding mine to carbon fiber? Maybe stay away from this stuff if using on plastic? Sorry guys!
Discussion Starter #11 (Edited)
That may be the issue... I guess ill find tape. You guys use this stuff?
Yep, I used this one since that's what the store had:
https://www.amazon.com/Scotch-Outdoor-Mounting-60-inches-411P/dp/B0083K36KA/
But they look to be basically the same thing. When I did mine, I cut the strip in half (long way), since it's a little wide right out of the roll. So you technically get more for your money!
Looks like they used black weatherstrip adhesive originally.
3M VHB tape is some amazing stuff. They put 18 wheeler trailers together with it.
This is what I used. Great stuff.
Administrator
Scuff the plastic part to provide tooth if applying adhesive if using tape you shouldn't have to.
1 - 15 of 15 Posts
