finally came across a dyno chart for the 120 hp Rover motor - here's the two next to each other for comparison:
Rover:
Toyota:
FYI: 100 ft-lbs == 136 Nm; so 160 Nm == 118 ft-lbs
... wow... if those are both corrected & accurate, the Toyota motors SUCKS at low (read: normal, everyday) rpm.
If someone else has a Rover dyno chart, you should post it.
FYI: the celica chart came from http://www.newcelica.org/other/dyno/index.htm
Rover:
Toyota:
