1 - 7 of 7 Posts
Has anyone removed the panel in the boot that gives access to the rear bank of coil packs/plugs? On the surface is appears to only be held in place by six 8mm bolts. However, on mine at least, it was also held in place by a liberal application of epoxy. It took me 45 minutes using a screwdriver to carefully cut/pry the metal panel away without bending or breaking anything. Was this a mistake, or am I missing the reason why they would glue the access panel shut? As far as I can tell, it is the only way to access the rear bank of plugs without major surgery. Pic of the panel once removed below.
Lynn, What did you need to access back there. Plugs good for ~100K. Bad coil??
It is meant to be a fireproof wall. On a good note, they took it seriously!
I put copper plugs in because I like to tinker and don't mind changing them every oil change. I know I'm weird. Also my cold startup (after sitting for a couple of days) is really rough. I am mildly curious to see if new plugs help that. Again, just tinkering.
There is a heat shield hatch on the other side of the metal hatch - it was easy to remove - 4 bolts. So it seems the boot is well protected.
It just seemed odd to have glued the metal panel to the fiberglass. But I'm a software guy, so WTF do I know.
Sent from my Autoguide iPad app
The boot needs to be sealed in order to keep water out. If you've noticed during car washes or rain showers, the engine compartment gets wet. I guess gluing keeps the water from entering the boot. Lotus takes water intrusion very seriously!:)
The exception being AC water. They consider that recycling.
Mine was exactly the same. When i Installed the exhaust system that panel had to be removed and it took me about 30 minutes to remove it.
1 - 7 of 7 Posts
