1 - 17 of 17 Posts
Forum Founder
So I am looking at the connector.
Figured out how to remove it, pull the retention tab thingie. Cover snaps off. Got it. Very short service loop on the harness makes dealing with the connector more difficult.
A large number of wires. How do I know which pin is which number? Does anyone have a diagram?
Thanks
Randy Chase said:
So I am looking at the connector. Figured out how to remove it, pull the retention tab thingie. Cover snaps off. Got it. Very short service loop on the harness makes dealing with the connector more difficult. A large number of wires. How do I know which pin is which number? Does anyone have a diagram? Thanks
Check moremonkey, but you must register.
Once you have the connectors off the ECU, remove the 3 nuts that hold the ECU in place, and pull the ECU from the vehicle. With a good light, you'll be able to see little numbers in the plastic on the connectors on the ECU side, those are the pin numbers.
At least I remember seeing the numbers on one side or the other, but I can't possibly imagine how I would have seen them on the harness side, due to the short service loop you mentioned.
Randy, email me and I will send you the pin diagram; I'd post it but it is in excel and I can't get the pin layout to format correctly. Also, I recommend double-checking pin function against the service manual.
AND FROM: http://www.elisetalk.com/forums/showpost.php?p=146888&postcount=73
aletes said:
1 Pre O2 Sensor - HT. Ground
3 Post O2 Sensor - Signal
4 Crank Sensor
6 SAI Pressure Sensor - Ground
7 Coolant Temperature
8 TP Sensor - 5v Reference
9 VSV (Canister Vent Close Valve)
11 VSV (ACIS) Airbox
12 Oil Control Valve VVL
13 Knock Sensor
14 Injector 3
15 Pre O2 Sensor - Signal
18 TMAF Sensor - IAT Ground
19 Knock Sensor
20 TP Sensor - Signal
21 Oil Pressure Switch - Block
22 Ignition Coil 1, 2, 3, & 4
24 Oil Pressure Switch (VVTIL)
25 Injector 1
26 Ignition Coil 2
27 Post O2 Sensor - HT. Ground
29 Post O2 Sensor - Ground
30 Crank Sensor
31 TMAF Sensor - MAF Ground
33 Coolant Temperature
34 TP Sensor - Ground
35 IAC Valve - Signal
36 SAI Pressure Sensor - 5v Reference
38 VSV (Purge Valve)
40 Injector 4
41 Pre O2 Sensor - Ground
43 Knock Sensor
44 TMAF Sensor - IAT Signal
45 TMAF Sensor - MAF Signal
47 Ignition Coil 3
48 Ignition Coil 4
49 Oil Control Valve - VVT
50 SAI Pressure Sensor - Signal
51 Injector 2
52 Ignition Coil 1
55 Fuel Tank Sender
76 Fuel Tank Sender
78 Fuel Tank Sender
ECU Bus
SPL CAN_L: Pin 79
SPL CAN_N: Pin 80
Diagnostic Connector
SPL CAN_N: Pin 6
SPL CAN_L: Pin 14
SPL U (GND): Pin 4 & 5
16-15-14-13-12-11-10-9
8--7--6--5--4--3--2--1
AND:
nevermind - Neeeeeeeeeeeewman got it ;-)
And jay Hassinger deserves credit for the emanage splicing part of this, I am pretty sure
Forum Founder
Thanks guys!
Good info, specially about unbolting the ECU. Duh! :)
have schematic, will scan
Randy,
I have a paper copy of the schematic that I can contribute if the pdf of the same thing is difficult to read. I confirmed portions to charliex already and can do the same here if needed.
If others want the same information, I can high resolution scan and add here.
Michael
Thanks
Hi Randy,
How do you get the cover off the wire harness connector after you remove it from the ECU?
1 - 17 of 17 Posts
