The circ only stays active if its above that temperature, so if what you're asking is what i think it is, the easiest way is to put a sense on that ?
The ECU shouldn't stay on longer than 15 seconds or so, unless the temperatures are already over the threshold, since once the engine is off, the temps aren't going to rise much.
I'll check on my bench ecu but i'd imagine some of the VRef's stay active when the ecu is still on.
I can't remember if the ACC stays energised in the car ( it'll probably float so a diode or such), but otherwise if you need a sense you can pick it up off the key circuit.
