The 111R ECU is an EFi-technologies unit that has been OEM'ed for Lotus. It is *not* the Denso ECU used by Toyota.
'Chipping' it won't be easy as it's not a high volume production ECU, so not much people are working on 'cracking' it. (same goes for the ECU used in the Rover powered S2's, which is a similar ECU and not the Rover MEMS)
Not to mention that 'chipping' an ECU on a normally aspirated engine without any other work (eg. cams, head, etc.) usually brings very little (if any) gains.
The ECU is made by EFi and may be based on their generic programmable engine management systems, but it has been modified for Lotus so the generic EFi programming tools probably won't work anymore.
A piggyback-ECU like the UniChip (name is not very good as it's not a 'chip') or some of the APEXi's could indeed be used and the factory ECU left alone if the engine is modified and would cause the factory mapping to be too far outside it's requirements.
Bye, Arno.
