1 - 10 of 10 Posts
Good evening. My friend just purchased a 26R style wheel to replace his original S1 wood wheel with. Problem is, we can't figure out how to remove it! My "modern" removal kit seems not designed for such a wheel as in there is no puller holes to bolt into. What are we missing?
Thanks in advance!
Aaron
THANK YOU! I wonder though... the space on the backside of the hub is very narrow... will the "teeth" fit?
Cheers,
Aaron
Loosen the big nut, don't remove it, then hold the wheel as best as you can and give a couple of sharp raps on the nut with a hammer, just to break the grip of the splines.
What kind of shape is the original in?
+1--rocking the hub gently back and forth (by pushing/pulling on the steering wheel) plus a few hammer taps should pop it right off.
I would be reluctant to use a puller, as the hub is most likely aluminum, which could be easily damaged. Try putting a little "Liquid Wrench" or similar on the splines, then try again the next day.
rubber mallet..........not a hammer. Better yet a small piece of wood wrapped in cloth.
tap tap, other side tap tap, other side tap tap...........
patience......
patience......
No I meant hammer - on the nut. I think you have misread or misinterpreted my post. You need shock to break the bond.
1 - 10 of 10 Posts
