FWIW; I installed the Kumho Ecsta XS 215/45R16 and 245/40R17 on Cup wheels with absolutely no clearance issues. I now have around a thousand miles on them. Very happy so far.
bump for same question please?What is the center bore size, front and rear? Looking at alternate rims and am concerned about being hub centric. Thanks!
Great info thank u
I know this is an old post but the RAC Monolites are actually almost 5 pounds lighter (54.56 lbs for above versus 49.764 for RACS). The above are 8.5 rear width versus 8 for the RACS. The TRMotorsport F1s are even lighter, but smaller widths (6.5 and 7.5 respectively). The Monolites and the F1s are forged.You could add TMR rims to your list (different than TRMotorsports).
http://www.lotustalk.com/forums/f157/racing-wheels-20309/index2.html
and on page #2 Podium Custom Parts
Not sure what the following all means (but the numbers and kg I understand) but they are the lightest forged wheels and wide enough to handle most tires.
They fit good and the car feels significantly better with them and the weights and widths were as advertised (which is a nice change compared to Rotas).
シリーズ1用で大変ご好評を頂いておりました5本スポークタイプのホイールですがこのたびトヨタエンジン車用に新発売いたします。
10本スポークとの違いはリアサイズにあります。
これまでの8Jに対し、8,5Jとよりワイドなタイヤでの走行を可能にしました。
*カラー:シルバー、ガンメタ、マットブラック
*サイズ:フロント 16X7J オフセット+33mm 5、12kg
リア 17X8,5J オフセット+43mm 7、28kg
定価:1set ¥307650(税込み)
フロント16X7J ¥70140(税込み)
リア17X8,5J ¥83685(税込み)
I no longer own a Lotus and I provided all raw data for somebody to take over. I hope that somebody will create a new thread, use the core data I provided and takes it from herewould it be possible to reorder the tires in the first post to separate wet tires and which ones are standard/sport ?
for example
Standard Dry
Standard Wet
Sport Dry
Sport Wet
